Zum Hauptinhalt wechseln
HP Chromebook 11A G8 EE Wi-Fi Card Replacement
Was du brauchst
  1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: Schritt 1, Bild 1 von 2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: Schritt 1, Bild 2 von 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using your tweezers, unplug the battery connector from the motherboard.
  5. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Using your tweezers, peel back the clear sheet covering the Wi-Fi card.
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card cover.
    • Using your tweezers, remove the cover.
  6. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: Schritt 6, Bild 2 von 2
    • Using your tweezers, unsnap the the coaxial antenna cables from the Wi-Fi Card.
    • Slide the Wi-Fi card out.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Alabama, Team 2-1, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-1, Bedsole Fall 2021
UA-BEDSOLE-F21S2G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 690
