Zum Hauptinhalt wechseln
HP Chromebook 11a-nb0013dx Battery Replacement
Was du brauchst
  1. HP Chromebook 11a-nb0013dx Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Chromebook 11a-nb0013dx Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Position your closed computer on a flat surface, with the back facing up.
    • Remove all eight 8 mm Philips #0 screws from the bottom cover.
  2. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the 4 rubber feet with a nylon spudger or an opening tool.
  3. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 3, Bild 1 von 1
    • Flip over your computer and open it.
    • Using a plastic pick, level up the edges of the keyboard by sliding the pick along the gap.
    • Apply downward pressure to separate the bottom of the Chromebook and the keyboard.
    • Do the same for all 4 sides of the keyboard until it starts to lift.
    • You should hear popping sounds as you slide the plastic pick along the edge.
  4. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently lift up the keyboard from the bottom.
  5. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 5, Bild 1 von 2 HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 5, Bild 2 von 2
    • Identify the zero insertion force (ZIF) connector.
    • Now, disconnect the cable by using the tip of the iFixit opening tool or your fingernail to flip up the small locking flap.
    • You can now gently pull out the cable.
    • No force is needed to plug in or remove the cable.
  6. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 6, Bild 2 von 2
    • Identify the second cable and the ZIF connector attatching the cable to the motherboard. Then, unclip it with the iFixit opening tool.
    • To do this, use the iFixit opening tool to flip up the small locking flap located on the ZIF connector.
    • Proceed by gently pulling the cable straight out of the connector to disconnect the cable.
    • Be careful, the cord is very fragile!
  7. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 7, Bild 1 von 1
    • Once the white cord is removed, this is what it should look like. At this point, you should be able to completely take off the keyboard.
  8. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 8, Bild 1 von 2 HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 8, Bild 2 von 2
    • Lift up the adhesive holding the battery connector.
    • Then, pull the battery connector straight towards you.
    • It is important to pull of the battery connector straight towards you to avoid breaking the vord.
  9. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 9, Bild 1 von 2 HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 9, Bild 2 von 2
    • Remove the four 4 mm Philips #00 screws.
  10. HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 10, Bild 1 von 2 HP Chromebook 11a-nb0013dx Battery Replacement: Schritt 10, Bild 2 von 2
    • Gently lift the battery by holding the top.
Abschluss
Nafisat Ibrahim
349 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 219
