Zum Hauptinhalt wechseln
HP Chromebook 14 G4 Battery Replacement
Was du brauchst
  1. HP Chromebook 14 G4 Battery Replacement, Keyboard Assembly: Schritt 1, Bild 1 von 2 HP Chromebook 14 G4 Battery Replacement, Keyboard Assembly: Schritt 1, Bild 2 von 2
    • Remove the thirteen 2.5 mm Phillips #0 screws on the underside of the laptop that secure the keyboard assembly.
    • Flip the laptop over and open the lid.
    • Insert a nylon spudger in the gap between the keyboard assembly and lower case.
    • Gently pry around the entire perimeter until the keyboard assembly fully releases.
  2. HP Chromebook 14 G4 Battery Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14 G4 Battery Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14 G4 Battery Replacement: Schritt 2, Bild 3 von 3
    • Slightly lift the keyboard assembly with care not to strain the attached ribbon cables.
    • Flip up the two black ZIF locking flaps that secure the keyboard and touchpad ribbon cables to their motherboard sockets.
    • Gently pull the keyboard and touchpad ribbon cables out of their motherboard sockets.
  3. HP Chromebook 14 G4 Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift the keyboard assembly off of the chassis.
  4. HP Chromebook 14 G4 Battery Replacement, Battery: Schritt 4, Bild 1 von 2 HP Chromebook 14 G4 Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use your fingernails to "walk" the battery connector out of its socket.
    • Avoid pulling on the wires.
  5. HP Chromebook 14 G4 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 4.1 mm screws securing the battery with a Phillips #00 screwdriver.
  6. HP Chromebook 14 G4 Battery Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 14 G4 Battery Replacement: Schritt 6, Bild 2 von 2
    • Use a nylon spudger or your fingernail to flip up the two black ZIF locking flaps that secure either end of the ribbon cable.
    • Grip each blue pull tab and gently remove the ribbon cables from their sockets.
  7. HP Chromebook 14 G4 Battery Replacement: Schritt 7, Bild 1 von 2 HP Chromebook 14 G4 Battery Replacement: Schritt 7, Bild 2 von 2
    • Lift the battery up and out of the chassis.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Christian Leaman
551 Reputation
3 Anleitungen geschrieben
Gateway, Team 8-3, Gonzalez Fall 2024 Mitglied von Gateway, Team 8-3, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G3
5 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 37
Insgesamt: 306
