Einleitung
This guide will require removal of 1x5mm screws. Be careful removing the wires, be sure to release them as instructed before pulling on them.
Was du brauchst
Flip the laptop so the base of the laptop is facing you.
Using the #00 screwdriver, unscrew the 13 screws.
Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
Lift the white flap and pull the blue ribbon towards you until it is disconnected.
Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
Lift the black flaps and gently pull the strip out.
Set the strip aside.
Remove the screw.
Use your fingers to pull the white tab out of the black slot above the battery.
6 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Nice guide, guys!
Thanks, hope it made life a bit easier for you!
Very clear and concise. Nice going! Thank you.
