Einleitung
This guide will require removal of 1x3mm screws.
Was du brauchst
Flip the laptop with the base of the laptop is facing you.
Using the #00 screwdriver, unscrew these screws.
Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
Lift the white flap and pull the blue ribbon towards you until it is disconnected.
Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
Use a #00 screwdriver to remove the two screws.
Using fingers or the spudger, slide out the black connector indicated on the left.
Undo the black tape located on the bottom from the frame of the laptop.
Lift the black flaps and gently pull the strip out.
Set the strip aside.
Remove the screw.
Use your fingers to pull the white tab out of the black slot above the battery.
Using a spudger, remove the white and black cables from the card.
Remove screw indicated by the red circle at the top of the card port.
Remove the 3 screws around the fan.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
Remove all of the indicated screws.
Pull up on black strip to remove the monitor cord.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Thanks so much for your clearly , detailed and easy to follow guide, nice job!
Can you add more storage on the HP Chromebook 14 SMB about 500GB. I also want to know if the Chromebook can run Windows 10 without any problems.
