Zum Hauptinhalt wechseln
HP Chromebook 14-ak013dx Charging Port Replacement
Was du brauchst
  1. HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 3 HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 3 HP Chromebook 14-ak013dx Charging Port Replacement, Charging Port: Schritt 1, Bild 3 von 3
    • Position the laptop so that the bottom is facing towards you and the fold facing away.
    • Using a plastic opening tool or another prying device, remove the five rubber stoppers on the upper side of the laptop to reveal screws.
    • Using a Phillips-head screwdriver or another capable tool, unscrew the thirteen 5.0 mm Phillips #1 screws on the base of the laptop.
  2. HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Flip the laptop over and open it so the keyboard is visible.
    • Using a plastic opening or prying tool, insert the tool between the keyboard and bottom casing. Then rotate the tool away from the laptop to open it up.
    • Be sure not to pull the keyboard away just yet as the ribbons are still connected.
  3. HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 3, Bild 1 von 3 HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 3, Bild 2 von 3 HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 3, Bild 3 von 3
    • Using a plastic opening tool or your fingers, lift the two black flaps that hold the ribbons connecting the keyboard and touch-pad to fully disconnect the keyboard from the laptop.
    • Disconnect the battery cable from the system board
  4. HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Partially remove the tape that is covering the two wires connecting to the wireless adaptor.
    • Disconnect the white and black wires from the adaptor and remove it from the plastic piece used to guide the wire to free up space.
    • The wires are labeled (1) and (2), make note of their position for reassembly
  5. HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 6, Bild 1 von 3 HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 6, Bild 2 von 3 HP Chromebook 14-ak013dx Charging Port Replacement: Schritt 6, Bild 3 von 3
    • Using a prying tool or your fingers, remove the charging port head.
    • Pull by the white plastic or by the wiring away from the connector to remove the piece completely.
    • Replace the broken charging port with a new one.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Igli Duro
200 Reputation
1 Anleitung geschrieben
USF Tampa, Team 10-2, Remmell Spring 2017 Mitglied von USF Tampa, Team 10-2, Remmell Spring 2017
USFT-REMMELL-S17S10G2
4 Mitglieder
2 Kommentare
Where can you find a replacement charger port? My model is HP chromebook 11 g5ee
Neah McGovern - Antwort
Worked! THANK YOU!
RACHEL LICATA - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 5,739
