Einleitung
A guide on how to remove the keyboard from the HP Chromebook 14-ak013dx
Was du brauchst
Using a p01 screwdriver bit, unscrew the 13 screws on the back of the laptop (two will be under the rubber footpads)
Flip to laptop over and raise the screen. You will need to use a tool to "pop" the keyboard off, slowly sliding the tool along the outside
Carefully raise the keyboard off the body of the laptop
Locate two ribbons connecting the keyboard to the motherboard
Gently flip up the bars holding the ribbons in place, and remove the ribbon
Separate the keyboard from the body of the laptop
Using a p001 screwdriver, remove the two screws holding the touchpad in place
Gently lift the bar holding the ribbon in place, and remove the ribbon
Carefully push on the 'knob' on the touchpad; the touchpad will fall out of the keyboard
Carefully store the touchpad separately from the keyboard if not immediately replacing the keyboard
To reassemble your device, follow these instructions in reverse order. Add the old touchpad to the new keyboard, and be careful reattaching all ribbons. Keyboard should 'snap' into place before put screws back on the body.
