Einleitung
This guide will walk you through the replacement of a dead or dying battery in your HP Chromebook 14-ak041dx. This replacement is a common need in the HP Chromebook 14-ak041dx, the computer will often not charge or hold a charge when plugged in and is in need of a replacement battery.
Was du brauchst
You will need a pair of tweezers and a Phillips screwdriver.
Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
Using a pair of tweezers, remove the five grey silicone covers.
Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
Place them aside where they will not be lost.
Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
Place the keyboard aside. Inspect for any visual damage or marks.
Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
