Zum Hauptinhalt wechseln
HP Chromebook 14-ca061dx Battery Replacement
Was du brauchst
  1. HP Chromebook 14-ca061dx Battery Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Chromebook 14-ca061dx Battery Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Chromebook 14-ca061dx Battery Replacement, Keyboard: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Battery Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Battery Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 14-ca061dx Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Battery Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 14-ca061dx Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Battery Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 5, Bild 3 von 3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Battery Replacement: Schritt 6, Bild 1 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 6, Bild 2 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 6, Bild 3 von 3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Battery Replacement: Schritt 7, Bild 1 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 7, Bild 2 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 7, Bild 3 von 3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Battery Replacement: Schritt 8, Bild 1 von 1
    • Lift the rest of the keyboard up from the base of the Chromebook.
  9. HP Chromebook 14-ca061dx Battery Replacement, Battery: Schritt 9, Bild 1 von 2 HP Chromebook 14-ca061dx Battery Replacement, Battery: Schritt 9, Bild 2 von 2
    • Remove the four 4mm Phillips #0 screws from the battery.
  10. HP Chromebook 14-ca061dx Battery Replacement: Schritt 10, Bild 1 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 10, Bild 2 von 3 HP Chromebook 14-ca061dx Battery Replacement: Schritt 10, Bild 3 von 3
    • Peel back the black electrical tape from the motherboard using a pair of tweezers.
    • Using your finger, pull the white plastic piece toward you.
  11. HP Chromebook 14-ca061dx Battery Replacement: Schritt 11, Bild 1 von 1
    • Remove the battery from the base of the Chromebook.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Jean Arevalo
778 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
3 Mitglieder
Ein Kommentar
Great job documenting the procedure.
Dennis Gregory - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 1,963
