Zum Hauptinhalt wechseln
HP Chromebook 14-ca061dx Daughterboard Replacement
Was du brauchst
  1. HP Chromebook 14-ca061dx Daughterboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    Kaufen
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 5, Bild 3 von 3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 6, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 6, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 6, Bild 3 von 3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 7, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 7, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 7, Bild 3 von 3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 8, Bild 1 von 1
    • Lift the rest of the keyboard up from the base of the Chromebook.
  9. HP Chromebook 14-ca061dx Daughterboard Replacement, Daughterboard: Schritt 9, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Daughterboard: Schritt 9, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement, Daughterboard: Schritt 9, Bild 3 von 3
    • Peel back the plastic covering the cables connecting the motherboard to the daughterboard.
    • Use the spudger tool to flip up the black plastic pieces from both cables.
    • Pull both cables toward the right to remove from the daughterboard.
    • Be sure to remove the cables carefully because they are fragile.
  10. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 10, Bild 1 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 10, Bild 2 von 3 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 10, Bild 3 von 3
    • Peel back the plastic covering from the smallest blue and white cable.
    • Flip up the white plastic piece using the spudger.
    • Pull the blue cable toward the right to remove it.
    • Be sure to remove the cable carefully because it is fragile.
  11. HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 11, Bild 1 von 2 HP Chromebook 14-ca061dx Daughterboard Replacement: Schritt 11, Bild 2 von 2
    • Remove two 4mm Phillips #0 screws.
    • Remove the daughterboard from the Chromebook.
Abschluss
Jean Arevalo
778 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 409
