Einleitung
Nowadays, laptop screens can be easily damaged. The HP Chromebook 14-ca061dx screen could be physically damaged, with broken glass, or black splotches on the display, or could be defective, without any signs of physical damage. A defective screen could display resolution lines, distorted coloring, or nothing at all. If you know these problems are caused by a broken, or defective a screen, you may just need a replacement. Follow this guide to help with your screen/display replacement.
Was du brauchst
Flip the Chromebook so that the underside is facing upwards.
Follow along the edge with the iFixit opening tool to unhinge the display frame.
Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
Use spudger or the iFixit opening tool to remove the bezel.
Pull bezel from the bottom, once all clips are detached.
Remove bezel.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
Eine weitere Person hat diese Anleitung absolviert.
