Zum Hauptinhalt wechseln
HP Chromebook 14-ca061dx Display Replacement
Was du brauchst
  1. HP Chromebook 14-ca061dx Display Replacement, Display: Schritt 1, Bild 1 von 3 HP Chromebook 14-ca061dx Display Replacement, Display: Schritt 1, Bild 2 von 3 HP Chromebook 14-ca061dx Display Replacement, Display: Schritt 1, Bild 3 von 3
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: Schritt 2, Bild 1 von 1
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: Schritt 3, Bild 1 von 1
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 14-ca061dx Display Replacement: Schritt 4, Bild 2 von 2
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: Schritt 5, Bild 1 von 2 HP Chromebook 14-ca061dx Display Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 14-ca061dx Display Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: Schritt 7, Bild 1 von 1
    • Remove the LCD/display panel from the Chromebook frame.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jean Arevalo
778 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
3 Mitglieder
Ein Kommentar
should disconnect the laptop battery first
TJ Kleckner - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 24
Insgesamt: 2,814
