Zum Hauptinhalt wechseln
HP Chromebook 14-db0000 Battery Replacement
Was du brauchst
  1. HP Chromebook 14-db0000 Battery Replacement, Disassemble Chassis: Schritt 1, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Disassemble Chassis: Schritt 1, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Disassemble Chassis: Schritt 1, Bild 3 von 3
    • Remove the Two (2) Rear RUBBER FEET
    • Remove the Seven (7) RUBBER "SCREW HOLE PLUGS"
    • Remove the Two (2) BLACK SCREWS from under the Rear Rubber Feet
    • There are Different Screws for the Two (2) Holes under the Rear Feet. (THEY ARE BLACK IN COLOR)
    • Remove the Seven (7) SILVER SCREWS
  2. HP Chromebook 14-db0000 Battery Replacement, Disconnect Keyboard Ribbon Cable: Schritt 2, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Disconnect Keyboard Ribbon Cable: Schritt 2, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Disconnect Keyboard Ribbon Cable: Schritt 2, Bild 3 von 3
    • VERY CAREFULLY Disconnect the KEYBOARD RIBBON CABLE
  3. HP Chromebook 14-db0000 Battery Replacement, Disconnect Trackpad Ribbon Cable: Schritt 3, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Disconnect Trackpad Ribbon Cable: Schritt 3, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Disconnect Trackpad Ribbon Cable: Schritt 3, Bild 3 von 3
    • VERY CAREFULLY Reconnect the TRACKPAD RIBBON CABLE
  4. HP Chromebook 14-db0000 Battery Replacement, Remove Old Battery: Schritt 4, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Remove Old Battery: Schritt 4, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Remove Old Battery: Schritt 4, Bild 3 von 3
    • Disconnect Battery Cable from Mainboard
    • Remove the Four (4) Screws that are holding the battery down.
  5. HP Chromebook 14-db0000 Battery Replacement, Install New Replacement Battery (Reverse of Step #5): Schritt 5, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Install New Replacement Battery (Reverse of Step #5): Schritt 5, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Install New Replacement Battery (Reverse of Step #5): Schritt 5, Bild 3 von 3
    • Replace the Four (4) Screws that Hold Down the Battery
    • Reconnect the Battery Power Cable to the Mainboard
  6. HP Chromebook 14-db0000 Battery Replacement, Reconnect Trackpad Ribbon Cable (Reverse of Step #3): Schritt 6, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Reconnect Trackpad Ribbon Cable (Reverse of Step #3): Schritt 6, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Reconnect Trackpad Ribbon Cable (Reverse of Step #3): Schritt 6, Bild 3 von 3
  7. HP Chromebook 14-db0000 Battery Replacement, Reconnect Keyboard Ribbon Cable (Reverse of Step #2): Schritt 7, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Reconnect Keyboard Ribbon Cable (Reverse of Step #2): Schritt 7, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Reconnect Keyboard Ribbon Cable (Reverse of Step #2): Schritt 7, Bild 3 von 3
    • VERY CAREFULLY Reconnect the KEYBOARD RIBBON CABLE
  8. HP Chromebook 14-db0000 Battery Replacement, Reassemble the Chassis (Reverse of Step #1): Schritt 8, Bild 1 von 3 HP Chromebook 14-db0000 Battery Replacement, Reassemble the Chassis (Reverse of Step #1): Schritt 8, Bild 2 von 3 HP Chromebook 14-db0000 Battery Replacement, Reassemble the Chassis (Reverse of Step #1): Schritt 8, Bild 3 von 3
    • Replace the BLACK SCREWS into the Holes Under the Rear Rubber Feet.
    • Replace the SILVER SCREWS into the Remaining Holes
    • Replace the Rubber Feet, and the Rubber "Screw Hole Plugs"
    • Charge your Chromebook to 100% Battery Capacity (feel free to use it during this step)
    • Once the battery is Fully Charged, with the Chromebook Still Powered On, Unplug the Charger and let the Battery Run Out of Charge (you can still use it during this step).
    • Once the Chromebook has shut down, let it sit unplugged for 30ish minutes.
    • Plug the Chromebook back in, and charge completely to 100% capacity, (you can resume use of the device during this step)
    • After all of the above Battery Calibration Steps are complete, your device is ready for normal use.
    • https://www.howtogeek.com/172271/how-to-...
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kingfisher
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 18
Insgesamt: 116
