Zum Hauptinhalt wechseln
HP Chromebook 14-q010nr Battery Replacement
Was du brauchst
  1. HP Chromebook 14-q010nr Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Battery Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14-q010nr Battery Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14-q010nr Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Battery Replacement: Schritt 4, Bild 1 von 1
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Battery Replacement: Schritt 5, Bild 1 von 2 HP Chromebook 14-q010nr Battery Replacement: Schritt 5, Bild 2 von 2
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 139
