Einleitung
This guide can be used for both missing keys and broken keys. Make sure that when you add a new key(s) to replace the missing/broken key(s) that the new key(s) matches the one you want to replace.
Turn off the Chromebook to avoid potential issues when replacing the keys. If you are only replacing a missing key and not a damaged one, skip the first step as it only applies to damaged keys.
Was du brauchst
Press on a key above the key you want to replace.
Place a flat object, like an iFixit opening tool in this case, under the broken key and lift upwards to remove it.
Align the square plastic bracket to make sure the keys fits there if the bracket moved.
To reassemble your device, follow these steps in reverse order.
