Zum Hauptinhalt wechseln
HP Chromebook 14-x010wm Battery Replacement
Was du brauchst
  1. HP Chromebook 14-x010wm Battery Replacement, Battery: Schritt 1, Bild 1 von 3 HP Chromebook 14-x010wm Battery Replacement, Battery: Schritt 1, Bild 2 von 3 HP Chromebook 14-x010wm Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the thirteen 5.7mm screws from the back of the laptop using a Phillips #00 screwdriver.
    • Remove rubber covers to reveal concealed screws, as needed.
  2. HP Chromebook 14-x010wm Battery Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14-x010wm Battery Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14-x010wm Battery Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over carefully and open the cover.
    • Use a plastic opening tool to pry open the front edge and along the sides of the keyboard cover to separate it from the computer’s base.
    • Lift the keyboard cover from the computer’s base carefully.
  3. HP Chromebook 14-x010wm Battery Replacement: Schritt 3, Bild 1 von 3 HP Chromebook 14-x010wm Battery Replacement: Schritt 3, Bild 2 von 3 HP Chromebook 14-x010wm Battery Replacement: Schritt 3, Bild 3 von 3
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
    • Lift the black plastic flap, using a plastic opening tool, of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by slowly pulling it from the system board.
    • Lift the black plastic flap that holds the battery cable in place using a plastic opening tool.
    • Remove the battery cable by slowly pulling the plastic connector towards you.
    • Remove carefully and set aside keyboard panel.
  4. HP Chromebook 14-x010wm Battery Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 14-x010wm Battery Replacement: Schritt 4, Bild 2 von 2
    • Flip the plastic flap holding the battery cable using a plastic opening tool.
    • Disconnect the battery cable by carefully pulling it from the system board.
  5. HP Chromebook 14-x010wm Battery Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-x010wm Battery Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-x010wm Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the seven M2xL3.0 screws from around the battery using a Phillips #00 screwdriver.
  6. HP Chromebook 14-x010wm Battery Replacement: Schritt 6, Bild 1 von 2 HP Chromebook 14-x010wm Battery Replacement: Schritt 6, Bild 2 von 2
    • Peel the wire band off of the battery carefully.
    • Remove the battery by lifting slightly, then slowly pull it towards you.
Abschluss
Follow these instructions in reverse order to reassemble your device.
Tyler Stover
137 Reputation
1 Anleitung geschrieben
IUPUI, Team S3-G3, Harley Spring 2019 Mitglied von IUPUI, Team S3-G3, Harley Spring 2019
IUPUI-HARLEY-S19S3G3
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 367
