Einleitung
This guide will walk you through all the steps necessary to remove the screen from your HP Chromebook 14-x010wm. Plan to allot roughly 1-3 hours to this project, as it requires major disassembly of the Chromebook. Also, you will need the tools listed in the details.
Was du brauchst
First, remove the 4 circled rubber feet on the base of the laptop to expose the screws beneath them.
Open the laptop.
Use an opening tool to separate the keyboard assembly from the rest of the computer by prying the two pieces apart.
Do this along the perimeter of the keyboard assembly to ensure it is fully seperated.
Once separated, carefully lift the keyboard assembly up and gently detach the two ribbon cables from the motherboard.
Detatch the display ribbon cable from the motherboard.
Gently pull the the black and white coaxial Wi-Fi cables from the motherboard.
To separate the screen assembly from the rest of the computer, remove the two screws that hold the hinges in place using the #00 phillips screwdriver.
The screen assembly can now be separated from the rest of the laptop.
Next, using the opening tool to sperate the frame from the screen-assembly backing.
Insert the opening tool at the base and work around the perimeter. It may be necessary to use the tool on the inside perimeter of the frame.
There are 4 screws holding each hinge in place: 3 at the base and 1 at the top. Use the #00 Phillips screwdriver to remove them.
Once all the screws are removed, the hinges can be lifted out.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
