Zum Hauptinhalt wechseln
HP Chromebook 14-x013dx I/O Board Replacement
Was du brauchst
  1. HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: Schritt 1, Bild 1 von 2 HP Chromebook 14-x013dx I/O Board Replacement, Keyboard, Touchpad: Schritt 1, Bild 2 von 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx I/O Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx I/O Board Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 14-x013dx I/O Board Replacement: Schritt 3, Bild 2 von 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx I/O Board Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 14-x013dx I/O Board Replacement: Schritt 4, Bild 2 von 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx I/O Board Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-x013dx I/O Board Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-x013dx I/O Board Replacement: Schritt 5, Bild 3 von 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: Schritt 6, Bild 1 von 2 HP Chromebook 14-x013dx I/O Board Replacement, I/O Board: Schritt 6, Bild 2 von 2
    • Unhook the ribbon connecting the I/O board and the battery.
    • To remove the ribbon, lift the latch holding the ribbons in place and then pull them free.
  7. HP Chromebook 14-x013dx I/O Board Replacement: Schritt 7, Bild 1 von 2 HP Chromebook 14-x013dx I/O Board Replacement: Schritt 7, Bild 2 von 2
    • Remove two 2mm screws from the I/O board using the Phillips PH00 screwdriver.
  8. HP Chromebook 14-x013dx I/O Board Replacement: Schritt 8, Bild 1 von 1
    • Lift the I/O board out of the laptop case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
NHerbert
602 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 456
