Zum Hauptinhalt wechseln
HP Chromebook 14-x013dx Screen Replacement
Was du brauchst
  1. HP Chromebook 14-x013dx Screen Replacement, Screen: Schritt 1, Bild 1 von 3 HP Chromebook 14-x013dx Screen Replacement, Screen: Schritt 1, Bild 2 von 3 HP Chromebook 14-x013dx Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
    • The nylon strips on the side may be difficult to remove, as they are held on with adhesive. A spudger can be used to help remove these strips before removing with fingers.
    • Remove the two 2mm screws holding the bezel to the laptop case.
  2. HP Chromebook 14-x013dx Screen Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 14-x013dx Screen Replacement: Schritt 2, Bild 2 von 2
    • Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
  3. HP Chromebook 14-x013dx Screen Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 14-x013dx Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove glued plastic at the bottom of the cover.
  4. HP Chromebook 14-x013dx Screen Replacement: Schritt 4, Bild 1 von 1
    • Once glue is separated, pop out the front cover by pulling upwards on the hinge.
  5. HP Chromebook 14-x013dx Screen Replacement: Schritt 5, Bild 1 von 2 HP Chromebook 14-x013dx Screen Replacement: Schritt 5, Bild 2 von 2
    • Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
  6. HP Chromebook 14-x013dx Screen Replacement: Schritt 6, Bild 1 von 3 HP Chromebook 14-x013dx Screen Replacement: Schritt 6, Bild 2 von 3 HP Chromebook 14-x013dx Screen Replacement: Schritt 6, Bild 3 von 3
    • Before completely removing the screen, detach the connected located at the bottom of the screen.
    • The connection to be removed should have a barcode marking.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
NHerbert
602 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,792
