Zum Hauptinhalt wechseln
HP Chromebook 14-x013dx Speakers Replacement
Was du brauchst
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: Schritt 1, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: Schritt 1, Bild 2 von 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement: Schritt 3, Bild 2 von 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement: Schritt 4, Bild 2 von 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-x013dx Speakers Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-x013dx Speakers Replacement: Schritt 5, Bild 3 von 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: Schritt 6, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: Schritt 7, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement: Schritt 7, Bild 2 von 2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: Schritt 8, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement: Schritt 8, Bild 2 von 2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: Schritt 9, Bild 1 von 1
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: Schritt 10, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement, Speakers: Schritt 10, Bild 2 von 2
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: Schritt 11, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement: Schritt 11, Bild 2 von 2
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: Schritt 12, Bild 1 von 2 HP Chromebook 14-x013dx Speakers Replacement: Schritt 12, Bild 2 von 2
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
NHerbert
602 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 241
