Zum Hauptinhalt wechseln
HP Chromebook 15 CB3-531-C4A5 Battery Replacement
Was du brauchst
  1. HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: Schritt 1, Bild 1 von 2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Case: Schritt 1, Bild 2 von 2
    • Remove the 18 Phillips screws using a screwdriver with a PH0 bit.
    Frag FixBot
    Kommentar hinzufügen
  2. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: Schritt 2, Bild 1 von 2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a spudger, gently pry open the back from the top.
    Frag FixBot
  3. HP Chromebook 15 CB3-531-C4A5 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Once it is opened up, locate the battery and the cable that is attached to it.
    Frag FixBot
  4. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: Schritt 4, Bild 1 von 2 HP Chromebook 15 CB3-531-C4A5 Battery Replacement: Schritt 4, Bild 2 von 2
    • Next, unscrew the battery pack. The one screw should be located on the far right of it. This will ensure that the battery comes out easily and affectively.
    Frag FixBot
  5. HP Chromebook 15 CB3-531-C4A5 Battery Replacement: Schritt 5, Bild 1 von 1
    • Take the battery out easily for replacement.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 29
Insgesamt: 2,406
