Einleitung
In this guide, we will be showing you how to remove the keyboard from your HP Chromebook CB2L.
Was du brauchst
Flip the Chromebook over so the blue panels are showing.
Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
Grabbing the boards by the edges, remove the motherboard and audio/USB board.
Remove the red and blue antennae wires from the SIM card board.
Remove the SIM card tray.
Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
