Zum Hauptinhalt wechseln
HP Chromebook x360 11-ae010nr Battery Replacement
Was du brauchst
  1. HP Chromebook x360 11-ae010nr Battery Replacement, Keyboard: Schritt 1, Bild 1 von 2 HP Chromebook x360 11-ae010nr Battery Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Flip the device upside down so that the screws are visible.
    • Loosen two captive Phillips #1 screws from the center of the device.
    • Remove three 9.3 mm Phillips #1 screws from the joint side of the device.
    • Remove four 6.1 mm Phillips #1 screws from the opening side of the device.
  2. HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 2, Bild 1 von 3 HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 2, Bild 2 von 3 HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert an iFixit opening tool between the edge of the keyboard assembly and the base of the device.
    • Push down on the handle of the opening tool to create an opening between the keyboard assembly and the base of the device.
    • Move the opening tool around the device, popping open the clips with force when necessary, until the keyboard assembly is fully lifted from the base of the device.
  3. HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 3, Bild 1 von 2 HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 3, Bild 2 von 2
    • Separate the keyboard assembly and the case.
    • Two cables connect the keyboard to the device, so take caution to not damage these cables.
    • Flip the black plastic tab where the wider cable meets the main board using the tip of a spudger or a fingernail.
    • Remove the cable with curved needle nose pliers or your fingers.
  4. HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 4, Bild 1 von 2 HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 4, Bild 2 von 2
    • Flip the white plastic tab where the thinner cable meets the main board using the tip of a spudger or a fingernail.
    • Separate the keyboard from the laptop.
  5. HP Chromebook x360 11-ae010nr Battery Replacement, Speakers: Schritt 5, Bild 1 von 2 HP Chromebook x360 11-ae010nr Battery Replacement, Speakers: Schritt 5, Bild 2 von 2
    • Remove the four 5 mm Phillips #1 screws from the left and right speakers.
  6. HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 6, Bild 1 von 2 HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the cable from the right speaker by removing the tape then detaching the cable.
  7. HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 7, Bild 1 von 1
    • Pull the white cable down to detach from the battery.
    • Remove the speakers from the laptop.
  8. HP Chromebook x360 11-ae010nr Battery Replacement, Battery: Schritt 8, Bild 1 von 2 HP Chromebook x360 11-ae010nr Battery Replacement, Battery: Schritt 8, Bild 2 von 2
    • Remove the two 5 mm Phillips #1 screws from each side of the battery.
  9. HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 9, Bild 1 von 2 HP Chromebook x360 11-ae010nr Battery Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the tape from the cable using a pair of tweezers.
    • Gently remove the cable from the plug.
    • Remove the battery from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Devin Cannistraro
193 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G9, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G9, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G9
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 11
Letzte 30 Tage: 48
Insgesamt: 2,257
