Zum Hauptinhalt wechseln
HP Chromebook x360 14-da0011dx Battery Replacement
Was du brauchst
  1. HP Chromebook x360 14-da0011dx Battery Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 2, Bild 1 von 2 HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 3, Bild 1 von 3 HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 3, Bild 2 von 3 HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. HP Chromebook x360 14-da0011dx Battery Replacement, Battery: Schritt 4, Bild 1 von 2 HP Chromebook x360 14-da0011dx Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the cable attached to the battery.
  5. HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 5, Bild 1 von 2 HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. HP Chromebook x360 14-da0011dx Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery out of the chassis.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jared Tallent
196 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 41
Insgesamt: 648
