Zum Hauptinhalt wechseln
HP Chromebook x360 14-da0011dx Lower Case Replacement
Was du brauchst
  1. HP Chromebook x360 14-da0011dx Lower Case Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. HP Chromebook x360 14-da0011dx Lower Case Replacement: Schritt 2, Bild 1 von 2 HP Chromebook x360 14-da0011dx Lower Case Replacement: Schritt 2, Bild 2 von 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. HP Chromebook x360 14-da0011dx Lower Case Replacement: Schritt 3, Bild 1 von 3 HP Chromebook x360 14-da0011dx Lower Case Replacement: Schritt 3, Bild 2 von 3 HP Chromebook x360 14-da0011dx Lower Case Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Where to get replacement parts for this one?
Aguinaldo Motta - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 65
Insgesamt: 369
