Einleitung
This guide outlines how to remove the battery of an HP Chromebook x360 14c-ca0053. The battery supplies power to the entire device and is a very vital part, so it is important to replace it if it is malfunctioning or not working entirely. Lagging, black screen, and frequent shut-downs could be indicative of a malfunctioning battery.
Was du brauchst
Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
Insert an opening pick between lower case and chassis.
Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
Open the tweezers wide enough to fit on each side of motherboard battery connection.
Pull the connector directly out of its socket.
Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
