Zum Hauptinhalt wechseln
HP Color LaserJet Pro MFP M277dw Power Button Replacement
Was du brauchst
  1. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove right side panel by prying it off.
    • Flipping the printer onto its side makes it easier to remove the side panel.
  2. HP Color LaserJet Pro MFP M277dw Power Button Replacement: Schritt 2, Bild 1 von 2 HP Color LaserJet Pro MFP M277dw Power Button Replacement: Schritt 2, Bild 2 von 2
    • Lower the front panel by pulling it down from the upright position.
    • The button cover should come off with the panel, if it does not be sure to remove it.
  3. HP Color LaserJet Pro MFP M277dw Power Button Replacement: Schritt 3, Bild 1 von 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: Schritt 3, Bild 2 von 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: Schritt 3, Bild 3 von 3
    • Remove two Phillips #2 8mm screws.
    • Unplug the wire connecting the power button to the circuit board by gently pulling them apart.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S4-G2, White Fall 2018 Mitglied von Cal Poly, Team S4-G2, White Fall 2018
CPSU-WHITE-F18S4G2
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
Ajay Kumar Singh - Antwort
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
Sheila Shook - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 39
Insgesamt: 2,687
