Einleitung
This guide will help you replace your power module in a HP Color Laser Jet Pro MFP M277dw.
Was du brauchst
Open and lower the back panel by pulling it down.
Remove one Phillips #2 10 mm screw.
Remove two Phillips #2 12mm screws.
Remove four different pin connectors that attach to the power module located at the bottom.
Remove two Phillips #2 10mm from the left (front) and right (back) side that attach the power module to the printer.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Hello, wäre can i buy the power supply? Thank you
Thanks a lot - also works for model M281fdw
