Einleitung
This guide will help you replace the wireless card in an HP Color LaserJet Pro MFP M277dw. You will need a plastic opening tool and a Phillips #2 screwdriver head.
Was du brauchst
Lower the back panel by pulling it down from the upright position.
Remove one Phillips #2 10mm screw.
Use the plastic opening tool to remove the left side panel.
2 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Would you share the part number of the module, better off a link to where it is sold. Thanks.
can this wireless card be upgraded to say a more modern one where it accepts wap3?
I’m just curious if you’ve ever left off the WiFi card and powered it up. Does the printer take away the entry for wifi settings on the display if you do this?
