Zum Hauptinhalt wechseln
HP Color LaserJet Pro MFP M277dw toner cartridges Replacement
Was du brauchst
  1. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, your printer: Schritt 1, Bild 1 von 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, your printer: Schritt 1, Bild 2 von 2
    • find the two notches on the side that allow you to easily open the front panel.
  2. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, Open the Front Panel: Schritt 2, Bild 1 von 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, Open the Front Panel: Schritt 2, Bild 2 von 2
    • Don't pull too hard as you might break your printer.
    • Pull both notches
  3. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, pull out the tray that contains the toner cartridges: Schritt 3, Bild 1 von 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, pull out the tray that contains the toner cartridges: Schritt 3, Bild 2 von 2
    • pull on the BLUE handle.
  4. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: Schritt 4, Bild 1 von 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: Schritt 4, Bild 2 von 2
    • take out your printer cartridges one-by-one.
    • dispose properly!
  5. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: Schritt 5, Bild 1 von 1
    • beware that there are little markings in each slot that says the color DO NOT MIX THESE UP
    • do not mix the cartridges up
    • do not touch the blue/green roller on the bottom of your new cartridges.
  6. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: Schritt 6, Bild 1 von 3 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: Schritt 6, Bild 2 von 3 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: Schritt 6, Bild 3 von 3
    • put them back in the printer
    • look at the pictures for more info
    • push the tray back and close the front panel
Abschluss
To reassemble your device, follow these instructions in reverse order. or look at the pictures on step 6.
2 weitere Personen haben diese Anleitung absolviert.
Seizure Salad
2.479 Reputation
2 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.525 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 40
Insgesamt: 2,998
