Was du brauchst
find the two notches on the side that allow you to easily open the front panel.
Don't pull too hard as you might break your printer.
Pull both notches
beware that there are little markings in each slot that says the color DO NOT MIX THESE UP
put them back in the printer
look at the pictures for more info
push the tray back and close the front panel
To reassemble your device, follow these instructions in reverse order. or look at the pictures on step 6.
2 weitere Personen haben diese Anleitung absolviert.
