Zum Hauptinhalt wechseln
HP Compaq 2510p Bluetooth Adapter Replacement
Was du brauchst
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: Schritt 1, Bild 1 von 1
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: Schritt 2, Bild 1 von 1
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: Schritt 3, Bild 1 von 1
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: Schritt 4, Bild 1 von 1
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: Schritt 5, Bild 1 von 1
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: Schritt 6, Bild 1 von 1
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Derek Kohansky
297 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 436
