Zum Hauptinhalt wechseln
HP Compaq 2510p WiFi Card Replacement
Was du brauchst
  1. HP Compaq 2510p WiFi Card Replacement, WiFi Card: Schritt 1, Bild 1 von 1
    • Flip the laptop over and locate the RAM cover plate towards the left of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p WiFi Card Replacement: Schritt 2, Bild 1 von 1
    • Using your Philips screwdriver, unscrew both screws.
  3. HP Compaq 2510p WiFi Card Replacement: Schritt 3, Bild 1 von 1
    • Lift the plate with your finger to remove it.
  4. HP Compaq 2510p WiFi Card Replacement: Schritt 4, Bild 1 von 2 HP Compaq 2510p WiFi Card Replacement: Schritt 4, Bild 2 von 2
    • Locate the screws at the top of the card and use your Philips screwdriver to remove them.
    • Be sure to ground yourself before touching components.
  5. HP Compaq 2510p WiFi Card Replacement: Schritt 5, Bild 1 von 1
    • Lift the card from underneath the top, using the spudger to leverage the card upwards. Then pull to release the card.
    • Always used ESD safe tools when repairing electronics. The black nylon spudger should be used whenever possible.
  6. HP Compaq 2510p WiFi Card Replacement: Schritt 6, Bild 1 von 1
    • Pull on each of the wires connected to the card. They will easily pop off and the WiFi card will be released.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Dan Champagne
178 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
what wifi cards does this notebook support?
plaui - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 638
