Zum Hauptinhalt wechseln
Einleitung
The hard drive is fairly easy to replace though it may seem intimidating at first glance. The only tool needed for this replacement guide is the PH00 bit. Don't worry about losing the two screws that get unscrewed because they stay attached to the device for your convenience. Make sure the device is off before starting the guide. If the device is unable to save any new data such as a photo or file, then the hard drive might need to be replaced.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
  2. Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
  3. Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
Abschluss
Aleks B
337 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 156
