Zum Hauptinhalt wechseln
HP Compaq 515 RAM Replacement
Was du brauchst
  1. HP Compaq 515 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Turn the laptop over. The screw for the RAM is located in the middle of the device.
  2. HP Compaq 515 RAM Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the small screw using a PH00 bit.
    • The screw is held in place, so there is no need to worry about losing it.
  3. HP Compaq 515 RAM Replacement: Schritt 3, Bild 1 von 2 HP Compaq 515 RAM Replacement: Schritt 3, Bild 2 von 2
    • There are two tabs on either side of the RAM card that are holding it in place. Slide them to the sides; one to the left and the other to the right. The RAM pops out.
  4. HP Compaq 515 RAM Replacement: Schritt 4, Bild 1 von 1
    • Slide the RAM card out of its socket.
  5. HP Compaq 515 RAM Replacement: Schritt 5, Bild 1 von 1
    • Repeat these steps for the second RAM card which is stored underneath the first one.
Abschluss
Aleks B
337 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 339
