Zum Hauptinhalt wechseln
Einleitung
Remove the power button panel from above the keyboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn off computer before starting. Flip to the backside of the laptop. Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. Flip over the laptop to the top side, and open the laptop.
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. Using the plastic prying tool, lift the keyboard gently towards you. Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. Pull up on both sides of the black locking tab of the connector.
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. Put a finger under each side of the plastic lock on the ribbon cable and pull up.
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. Using a flathead screwdriver, get under each plastic hinge cover until they pop. Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free. Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Khulan Orgil
1.093 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 4-2, Maness Spring 2015 Mitglied von Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 11
Insgesamt: 2,903
