Zum Hauptinhalt wechseln
HP Compaq 6710b Wireless Card Replacement
Was du brauchst
  1. HP Compaq 6710b Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Wireless Card Replacement, Wireless Card: Schritt 2, Bild 1 von 2 HP Compaq 6710b Wireless Card Replacement, Wireless Card: Schritt 2, Bild 2 von 2
    • Make sure the computer is off.
    • Using a Phillips #1, unscrew the 5mm screw on the bottom of the laptop
    • Remove the back cover plate.
    • The cover has popping tabs so it might require a small amount of force to remove.
  3. HP Compaq 6710b Wireless Card Replacement: Schritt 3, Bild 1 von 2 HP Compaq 6710b Wireless Card Replacement: Schritt 3, Bild 2 von 2
    • Using a blue plastic prying tool, gently pry off the 2 connectors.
    • The black cable goes on the connection closer to where the cables originate, while the white cable goes on the farther connection.
  4. HP Compaq 6710b Wireless Card Replacement: Schritt 4, Bild 1 von 2 HP Compaq 6710b Wireless Card Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips #1 screwdriver, unscrew the 2 3mm screws.
    • Adaptor is spring-loaded.
    • You can now take out the adaptor.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Khulan Orgil
1.171 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 4-2, Maness Spring 2015 Mitglied von Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 2,561
