Zum Hauptinhalt wechseln
HP Compaq 6730b Display Replacement
Was du brauchst
  1. HP Compaq 6730b Display Replacement, Display: Schritt 1, Bild 1 von 3 HP Compaq 6730b Display Replacement, Display: Schritt 1, Bild 2 von 3 HP Compaq 6730b Display Replacement, Display: Schritt 1, Bild 3 von 3
    • Okay, so here is a HP 6730b that was accidentally dropped. The cracks in the LCD are clearly visible on the left side of the image.
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
    • Close the screen and turn the computer over. Remove the memory/WLAN module compartment cover by loosening the Phillips 2.0×5.0 "captive" screw. They are secured by a spring clip at the back, so they will not be easily removed. All that is required is to loosen those.
    • Disconnect the WLAN antenna cables from the terminals on the WLAN module. The black cable is connected to the WLAN module “Main” terminal. The white cable is connected to the WLAN module “Aux” terminal.
  2. HP Compaq 6730b Display Replacement: Schritt 2, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 2, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery. Slide the locking tab to the left and release the battery.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the computer.
    • Turn the computer display-side up, with the front toward you. Open the computer as far as possible. There are four retention tabs that hold the keyboard down.
  3. HP Compaq 6730b Display Replacement: Schritt 3, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 3, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 3, Bild 3 von 3
    • Use a small screwdriver, or other instrument, to slide the four tabs in a downward direction toward the palmrest.
    • Gently lift the keyboard up from the display side,
    • and tilt it toward the front of the computer. Do not lift it up to fast or to high, the keyboard ribbon cable is still connected.
  4. HP Compaq 6730b Display Replacement: Schritt 4, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 4, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 4, Bild 3 von 3
    • Here is the keyboard ribbon cable seated in the zero insertion force (Zif) connector.
    • Release the ZIF connector to which the keyboard cable is attached, by lifting the clasp in an upward direction. Disconnect the keyboard cable from the system board.
    • Release the Zif connector to which the power button board cable is connected, by lifting the clasp of the Zif connector in an upward direction.
  5. HP Compaq 6730b Display Replacement: Schritt 5, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 5, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 5, Bild 3 von 3
    • Lift the left and right sides of the switch cover until it detaches from the computer, but do not yet try to remove it.
    • The LED board cable is still attached, disconnect it from the Zif connector by simply pulling it out in an upward direction.
    • With both ribbon cables disconnected, remove the switch cover.
  6. HP Compaq 6730b Display Replacement: Schritt 6, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 6, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 6, Bild 3 von 3
    • Remove the fan connector. (it is not necessary to use forceps or any other tool)
    • Loosen the two Phillips 2.5×7.0 screws that secure the fan to the base enclosure.
    • Remove the fan from the case.
  7. HP Compaq 6730b Display Replacement: Schritt 7, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 7, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 7, Bild 3 von 3
    • Close the computer and position it with the rear panel toward you. Remove the four Torx T8 M2.5×9.0 screws that secure the display assembly to the computer.
    • There are two on the left side,
    • Notice cracked bottom case from impact, no sequela from it.
    • and two screws on the right. Note the slots in the screw heads. these screws can also be removed with a flat tip screwdriver.
  8. HP Compaq 6730b Display Replacement: Schritt 8, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 8, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 8, Bild 3 von 3
    • Position the computer with the front toward you and open the computer as far as possible.
    • Disconnect the display panel cable from the system board, by pulling the connector from the socket. Do not pull the cable, but pull on the connector.
    • Disconnect the camera cable from the system board.
  9. HP Compaq 6730b Display Replacement: Schritt 9, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 9, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 9, Bild 3 von 3
    • Remove one of the two T8 M2.5×9.0 screws that secure the display assembly to the computer. The screw on the left display assembly hinge secures a display panel cable ground loop.
    • The second screw on the left side is only 3mm in length but must be removed as well
    • Pull the two antenna cables out from the bottom of the case.
  10. HP Compaq 6730b Display Replacement: Schritt 10, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 10, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 10, Bild 3 von 3
    • Remove the T8 M2.5×9.0 screws on the right side hinge.
    • Now remove the screw from the left hinge that holds the ground loop. the display is no longer supported, so lift it straight up.
    • The microphone cable is still attached.
  11. HP Compaq 6730b Display Replacement: Schritt 11, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 11, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 11, Bild 3 von 3
    • Disconnect the camera cable. The display can now be separated from the bottom case.
    • There are four beveled rubber screw covers on the display bezel top edge.
    • and two flat rubber screw covers on the display bezel bottom edge
    • These are simply glued in. Use a small screwdriver or similar instrument to remove them
  12. HP Compaq 6730b Display Replacement: Schritt 12, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 12, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 12, Bild 3 von 3
    • under the screw covers are six Torx T8 M2.5×7.0 screws that secure the display bezel to the display assembly.
    • Remove all six of those.
    • Use a plastic opening tool to insert at the edge of the bezel and move it along the whole bezel.
  13. HP Compaq 6730b Display Replacement: Schritt 13, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 13, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 13, Bild 3 von 3
    • It does not require any force to pop the bezel of its clips. Just use the opening tool gently along the edges.
    • Remove the bezel to expose the LCD
    • Remove the two T8 M2.5×7.0 screws on the right, that secure the display panel to the display enclosure.
  14. HP Compaq 6730b Display Replacement: Schritt 14, Bild 1 von 3 HP Compaq 6730b Display Replacement: Schritt 14, Bild 2 von 3 HP Compaq 6730b Display Replacement: Schritt 14, Bild 3 von 3
    • Remove the two T8 M2.5×7.0 screws on the left, that secure the display panel to the display enclosure.
    • Disconnect the backlight cable from the display inverter.
    • Disconnect the display panel cable from the display inverter
  15. HP Compaq 6730b Display Replacement: Schritt 15, Bild 1 von 2 HP Compaq 6730b Display Replacement: Schritt 15, Bild 2 von 2
    • The last steps are to remove the display hinges from the LCD panel. Remove the four Phillips screws from each side of the panels. The panel is now ready to be replaced.
    • With everything re-assembled, hopefully this is something like what you will see.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
oldturkey03
782.480 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
544 Anleitungen geschrieben
6 Kommentare
A great guide - clear instructions. However, there was a missing step at the end, step 15, which was to move the ribbon cable from the back of the old screen on to the new screen. My new replacement screen didn't have this cable, but moving it is easy enough to do. Thanks!
John - Antwort
I would like to express my thanks to the author of this guide - the instructions are extremely comprehensive and the pictures are very helpful. As with the earlier contributor, I had to move across the cable from my old screen to the new one, but much more importantly thanks to the guidance set out above I once more have a laptop I can use. Thanks again!
David - Antwort
This is terrific! I followed it to replace a broken hinge on my laptop, and everything worked well. Replacing the camera/mic cable upon reassembly is a very fiddly operation . Other than that this guide is flawless. Thanks!
Ellis Jones - Antwort
I just completed this replacement today and this guide was a great help. The steps were easy to follow and made the process smooth and painless. I have added one small correction to the text in Step 10 c. The connector shown is for the pair of microphones located in the top of the bezel. Thanks for the help.
Duncan Spencer - Antwort
loved this thank you.
brian ayienda - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 39
Insgesamt: 17,084
