Einleitung
if your laptop isn't turning on when plugged in this might be the case
secondly remove the screws in the battery compartment labelled with a keyboard icon
and then the top 2 and middle screws in the battery compartment
thirdly you will want to remove the screws from the top corners of the laptop
then on the topside of the laptop and the display open to reveal the keyboard then the black border of the keyboard slides up and releases is it doesn't check if you have missed any screws after that gently release the ribbon cable from the socket
forth, unscrew the 2 screws holding the warrior board in then change it with your new one and screw it back in, do everything in reverse to reassemble
Was du brauchst
First remove the battery from the laptop via sliding the release catches.
To reassemble your device, follow these instructions in reverse order. it is also possible dur in reassemble to snap the ribbon cable on the keyboard and power board
