Einleitung
Complete Disassembly of The Laptop excluding Laptop Display
Was du brauchst
Remove the 3 screws from the Ram Cover and lift up the cover
Remove Ram Stick by pulling the tabs to it side
Remove the to remove the Wifi Card and remove its antenna wires
Remove 2 Screw from the Hard Drive Cover and lift up the cover
Remove 10 screws from the laptop
Remove 3 2.5 x 6.5 screws from the laptop
Remove 3 2.5 x 5 screws from the laptop
Remove 4 2.5 x 3 screws from the laptop
Put Your Hands on the Top Corners and Put some little pressure
Remove the Ribbon Cables and Wires from the Motherboard and use a pick to remove the top cover
Remove 1 screw and lift up the top cover
Remove the 3 Display Cables and a USB Port Ribbon Cable
Remove the Power Cable and pull the motherboard to the right
Remove the Six Screws from the Heatsink
Remove the Cable of the fan
Laptop Dissasembly Complete, Here is Everything except for the Case and Display
To reassemble your device, follow these instructions in reverse order. This can be useful for a CPU Upgrade
7 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Thank you so much . I learned to unlock the device by following the illustrations
