Einleitung
Use this guide to replace the RAM stick. If your computer freezes up momentarily while running several programs, this may be the guide for you.
Was du brauchst
Ensure the laptop is unplugged and completely powered off. Loosen the three small screws using a #1 Phillips screwdriver.
Carefully pry the panel up using a plastic opening tool.
Pull the panel away from the laptop and set it off to the side.
2 weitere Personen haben diese Anleitung absolviert.
