Einleitung
Use this guide to fix wireless connectivity issues by replacing the defective wifi card.
Was du brauchst
Use a Phillips screwdriver with a PH1 bit to loosen the three indicated screws.
Use the same screwdriver to remove the two 3 mm screws holding the card in place.
3 weitere Personen haben diese Anleitung absolviert.
