Zum Hauptinhalt wechseln
HP Compaq Presario V3000 Battery Replacement
  1. HP Compaq Presario V3000 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Battery Replacement: Schritt 2, Bild 1 von 2 HP Compaq Presario V3000 Battery Replacement: Schritt 2, Bild 2 von 2
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Battery Replacement: Schritt 3, Bild 1 von 2 HP Compaq Presario V3000 Battery Replacement: Schritt 3, Bild 2 von 2
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ricky Jaimez
369 Reputation
2 Anleitungen geschrieben
University of Memphis, Team 1-4, Kim SU 2016 Mitglied von University of Memphis, Team 1-4, Kim SU 2016
UM-KIM-SU16S1G4
3 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
I need the battery remove switch
Aadhi Dev - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 2,543
