Einleitung
This guide will show how to remove and replace RAM
Was du brauchst
Locate the two screws holding the RAM cover in place
Use Phillips #0 screwdriver to remove the two 4.5mm Philips head screws
Lift the RAM cover towards the battery eject latch
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, carefully pull the RAM chip away from the RAM slot
Push retention clip on each side of the second RAM chip OUTWARDS
RAM chip will pop up
2 weitere Personen haben diese Anleitung absolviert.
