Einleitung
This guide will walk you through the process of accessing, removing and replacing the Cooling Fan for a Compaq Presario V5303NR. The process of accessing the fan will need to be done if the user is thoroughly cleaning the cooling fan. Replacement, meanwhile, needs to be done if the fan is damaged or otherwise rendered inoperable.
The fan in the V5303NR is much less accessable than the fans in most modern laptops, making this process relatively difficult to do and with a slight risk of further damaging the components if improperly done.
Was du brauchst
Turn the laptop bottom-side up.
Push the battery latch to the left position to unlock the battery.
Remove the battery from its socket.
Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
Use the metal spudger to pry open the two metal latches affixing the fan cover to the laptop.
Use the Phillips #00 screwdriver to remove the 4mm #00 screw affixing the fan cover to the laptop.
Carefully unplug the plastic piece at the end of the wire from the motherboard at the highlighted point.
Carefully remove said plastic piece from the end of the wire bundle at the end of the wire.
Use the Phillips #00 screwdriver on the three 4mm #00 screws affixing the fan to the laptop.
Carefully unweave the fan's wire from the two highlighted overhangs holding it in place.
Feed the wire and wire bundle through the hole in the fan case.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
