Einleitung
This guide will walk you through the process of accessing, removing and replacing the Disk Drive for a Compaq Presario V5303NR. The process of accessing the disk drive will need to be done for replacement if the disk drive is faulty or damaged.
Was du brauchst
Turn the laptop bottom-side up.
Push the battery latch to the left position to unlock the battery.
Remove the battery from its socket.
Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
