Einleitung
In this guide it will take you through the process of replacing the motherboard. Please make sure the screws from the prerequisite guides are removed.
Was du brauchst
With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
In the battery housing, there are three screws that hold the keyboard on. These screws are located on the side near the front.
In the center of the bottom of the computer between the RAM and the wifi antenna is a 4th keyboard screw that also needs to be removed.
Open up the front of the laptop. Use a plastic opening tool to carefully pry open the keyboard from the edges.
Locate the keyboard cable/wire that attaches the keyboard to the laptop .
Locate the latch of the wire connector
Unlatch the wire connector and gently pull out the wire with your hands
Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
Locate the three tab holding down the cover of the Motherboard.
Lift the tabs with using either a plastic opening tool or your fingers.
Locate the four cables securing the Motherboard.
Gently pull cables to unsecure them.
3 weitere Personen haben diese Anleitung absolviert.
