Zum Hauptinhalt wechseln
HP Compaq Presario cq62-214nr Wireless Card Replacement
Was du brauchst
  1. HP Compaq Presario cq62-214nr Wireless Card  Replacement, Battery: Schritt 1, Bild 1 von 2 HP Compaq Presario cq62-214nr Wireless Card  Replacement, Battery: Schritt 1, Bild 2 von 2
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. HP Compaq Presario cq62-214nr Wireless Card  Replacement, Wireless Card: Schritt 2, Bild 1 von 2 HP Compaq Presario cq62-214nr Wireless Card  Replacement, Wireless Card: Schritt 2, Bild 2 von 2
    • Remove the three M2.5x5 mm Phillips screws securing the memory case.
  3. HP Compaq Presario cq62-214nr Wireless Card  Replacement: Schritt 3, Bild 1 von 2 HP Compaq Presario cq62-214nr Wireless Card  Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, insert it alongside any openings on the case. Lift and slide the tool to remove the case.
  4. HP Compaq Presario cq62-214nr Wireless Card  Replacement: Schritt 4, Bild 1 von 1
    • Locate the the Wireless Card located next to the RAM chips.
  5. HP Compaq Presario cq62-214nr Wireless Card  Replacement: Schritt 5, Bild 1 von 1
    • Remove the single M2.5x3 mm Phillips screw.
  6. HP Compaq Presario cq62-214nr Wireless Card  Replacement: Schritt 6, Bild 1 von 1
    • Using your hands, gently remove the cables connected to the wireless card.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Roth Marcelin
726 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 2-6, Sullivan Fall 2016 Mitglied von USF Tampa, Team 2-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 504
