Einleitung
This guide will provide information on how to replace the LCD screen if you ever experience black out screen issues.
Was du brauchst
Carefully flip the device over so that the bottom is facing up.
Slide both of the latches to the left.
Remove the four 1.2mm Phillip #1 screws circled.
The laptop may have rubber covers over the screws,. Remove them using a pointed tool to pry them out.
Pry up the plastic screen cover with the pry tool.
Once a corner of the plastic screen cover is lifted, slide the pry tool around the entire screen until the screen is completely lifted from the base.
Gently lift the monitor, from the base of the laptop.
The laptop will still be connected to the monitor wires located at the bottom of the screen.
All cables should be disconnected from the sensor board. Remove the eight 2mm Phillip screws attaching the bezel to the side of the monitor.
Attach the bezel to the new replacement screen.
