Einleitung
This guide will show you how to remove the RAM from a HP Compaq nc8430.
Was du brauchst
Carefully flip the device over so that the bottom is facing up.
Slide both of the latches to the left.
Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
Use fingers or tools to press the clamps that hold the RAM in to the side.
